AMP Controller Backend Connection Loss
  • 46 Views
  • Last Post 5 days ago
theDarkPotato posted this 2 weeks ago
OS: Windows Server 2019 Datacenter (Controller: Desktop Experience; Target: Server Core w/ FoD) Product: CubeCoders AMP v10.9.9.10 (b. 23-Jun-20)
Problem: The AMP Controller locks up after a while, with following error: 'Reconnecting Your connection to the AMP backend was lost. AMP will attempt to reestablish a connection.. If you chose to have your password remembered, you will be logged in automatically without interruption.'
The Controller is clearly pingable and refreshing the page wout/ cache (Ctrl+F5) results in the page being reloaded, but continuing to display the error.
Reading the logs, it seemed to be a target failing to connect, however this issue was resolved the same error is occuring. This issue is UNLOGGED by the ADS Instance.
Steps to Reproduce: Configure a split deployment
Actions Taken so far: Resolved bad connections to the ADS Controller.
Domekologe posted this 5 days ago
I have the same issue with Firefox. Did you try it with Google Chrome? With that browser all is working fine.
theDarkPotato posted this 5 days ago
We've been discussing this on the bug tracker. It is a known issue and not browser dependant. We've tried Internet Explorer, Edge, Firefox and Chrome. Mike told us it has been fixed in the nightly build
Close
