AMP running in Docker- ADS01 Won't start in AMP web portal, but shows running in CLI
  • 249 Views
  • Last Post 14 October 2019
dpd26 posted this 08 October 2019
I've got AMP 1.8.7.0 running in Docker on a Ubuntu server. Everything appears to work fine apart from the portal shows ADS01 isn't running, but when i check in CLI it shows it as up. Pictures below to demonstrate.
Web Snip
CLI Snip
Any help appreciated. This is a new AMP instance with McMyAdmin2 license. Moved old minecraft data over to new instance
Thanks Darrell
Mike posted this 08 October 2019
Are you able to access it via ampinstmgr view ?
Yeah, that seems to work fine
Is ADS itself running inside docker?
Not 100% sure, it's my first time using docker. (Self teaching, yay!) I created this setup by doing a pull on cubecoders/amp and deploying that way. All of the instances ADS01 and McMyAdmin are in the same container if that helps
Thanks Darrell
Ah, the cubecoders/amp container is completely untested and probably doesn't work. You're supposed to install as per the normal guide and just turn on the docker flag in ADS once that is set up.
Ahhh no worries, I'll give that a go then! Could you pop us a link to the guide and I'll give it a bash?
Thanks also for replying at ludicrous times of the evening, can't mess with this stuff during the day job
Thanks Darrell
https://cubecoders.com/AMPInstall :)
dpd26 posted this 10 October 2019
Hi Mike,
Thanks for that, works a treat now as it's installed that way. One issue i'm having is when I add an SSL (One i purchased) to the ADS server, and change the Auth in the minecraft server to https, it doesn't work saying it can't find the auth server. Is there another config file or option i need to change for SSL?
Thanks Darrell
Mike posted this 14 October 2019
You need to change both the default auth server URL and the Login.AuthServerURL in AMPConfig.conf for any existing instances.
Close
