AMP running with rt kernel and gamemoderun
  • 102 Views
  • Last Post 11 July 2021
  • Topic Is Solved
blackzero23 posted this 09 July 2021
Hello, can i run AMP with the Parameter gamerun??? I have an rt kernel from this site https://xanmod.org/ It is the 5.10.47-rt45-xanmod1
I have to use it
For games/launchers which integrate GameMode support (see list later on), simply running the game will automatically activate GameMode.
For others, you must manually request GameMode when running the game. This can be done by launching the game through gamemoderun:
gamemoderun ./game
Or edit the Steam launch options:
gamemoderun %command%
Can i run AMP with this parameter?
Mike posted this 09 July 2021
Probably, but we don't offer any support for this. It's probably doable, but you're on your own with this.
You probably just need to edit the systemd file to run gamemoderun ampinstmgr startboot but again - zero support for this.
blackzero23 posted this 10 July 2021
When i start Minecraft and csgo in wich file i cant finde the startparameter for this???
/home/amp/.ampdata/instances/AmineXWarserver/AMP_Linux_x86_64 +Core.Webserver.Port 8082 +Core.Webserver.IPBinding 127.0.0.1 +FileManagerPlugin.SFTP.SFTPPortNumber 2225 +srcdsModule.SRCDS.ServerPortBinding 27015 +srcdsModule.SourceTV.SourceTVPort 27020
/home/amp/.ampdata/instances/AmineXWarserver/./srcds/740/srcds_linux -game csgo -console -usercon -ip 217.79.189.160 -port 27015 +rcon_password xxxxxxxxxxxxxxxxx+map cs_agency +maxplayers 12 +hostname AmineX | Warserver | Tick 125 | Source TV +sv_password xxxxxxxxxxxx+sv_pure 1 exec autoexec.cfg +log on -tickrate 125 +game_type 0 +game_mode 1 +mapgroup mg_active -maxplayers_override 12 +sv_setsteamaccount xxxxxxxxxxxxxxxxxxxxxxxx
/usr/lib/jvm/adoptopenjdk-8-hotspot-amd64/bin/java -Xmx10240M -jar forge-1.12.2-14.23.5.2855.jar nogui
in wich file i cant finde this parameters???
Mike posted this 11 July 2021
You don't. AMP controls all the parameters. You also should take more care not to post personal information in your posts.
You start AMP with gamemoderun - it's not necessary to start the individual applications that way.
But again, this is an unsupported configuration - we won't offer any support for using this. You're on your own here.
Close
