Factorio Instance Refuses to start (Nightly Build)
  • 254 Views
  • Last Post 07 November 2019
  • Topic Is Solved
Ohno2 posted this 07 November 2019
OS: Windows
Name/Version: AMP Version 1.9.0.0 (Nightly)
Description of issue:
I have started a Factorio instance and it is unable to start. I have added a default.zip file in the "saves directory" but have not changed any other settings. The server gives the error "could not complete action" when I try to start it. I have updated the server to the most recent version through the "Update" button and have tried F5.
LOGS RETURN:
[02:29:13] [APIService:ohno2 Error] : WebException
[02:29:13] [APIService:ohno2 Error] : [0] (WebException) : The remote server returned an error: (500) Internal Server Error.
[02:29:13] [APIService:ohno2 Error] : at Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
at Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result)
at Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result)
at AMPAPI.RemoteInstance.d__15`1.MoveNext()
at AMPAPI.RemoteInstance.API_Core.()
at GSMyAdmin.WebServer.WebMethods.()
at GSMyAdmin.WebServer.WebAttributes.InvokeMethod(String MethodName, JObject Data, IHttpRequest request, IWebSession Session, WebMethodsBase MethodsClass, String RawRequest)
at GSMyAdmin.WebServer.APIService.InvokeAPI(IHttpRequest request, IWebSession Session, JObject Data, String RequestModule, String RequestMethod, String RawRequest)
Module: Factorio
Mike posted this 07 November 2019
AMP 1.9 has just shipped, so set up a fresh install and see if the issue persists.
Fixed the startup issue, thank you!
Close
