Help for McMyadmin3
  • 168 Views
  • Last Post 5 weeks ago
  • Topic Is Solved
M_Patate83 posted this 14 January 2020
Hello I am a long time user of McMyAdmin2. I would like to switch to McMyAdmin3 with AMP.
I installed AMP on debian 10. And I find it much more complicated.
Can you explain to me how to define the ip address and the port of the web interface of AMP. I would like this to be one of my IP Fail over ?
I also have a second problem how to define the minecraft server folder like on MCMA2 ?
Thanks for your help.
M_Patate83 posted this 5 weeks ago
Thank you for your links,
I took the time during the week to test amp with MCMA 3 it works perfectly well thank you.
I still have a problem, how do you change the port of the web server when I create a new instance? I saw the default system 8080: 8180, but I would like for example to put on my MCMA instance (1) the port 31542, on my MCMA instance (2) the port 24587, etc.
Mike posted this 5 weeks ago
Right click the instance in ADS and hit "Edit Ports". You can also edit under "Configuration > New instance defaults" the port ranges that ADS will use.
I probably misspoke. I would like to change the port to connect to the web interface via the internet (firefox, safari, etc.).
Currently if I right click on ADS01, in port binding I have nothing. and in MCMA3 I only have "MinecraftModule.Minecraft.PortNumber"
ampinstmgr rebind while ADS is stopped. Just bare in mind you can't use ports below 1024. Also what I said about the port ranges in the configuration still applies to this.
Thank you, works perfectly !
Close
