How to change max player amount to something bigger than 10??
  • 763 Views
  • Last Post 31 December 2017
  • Topic Is Solved
Vilzu45 posted this 28 December 2017
I have an problem with the max player amount. I want to change the amount to 30 and i have been on the config file. I tried to change it to 50 in the config file but when i saved the config and restarted the mcmyadmin.exe file it came back to 10. How can i fix this?? Someone please help!
Mike posted this 28 December 2017
Is this with McMyAdmin 2? If so do you have a Pro licence?
Vilzu45 posted this 29 December 2017
Yes. It is for mc my admin 2,. I think i have a pro license
Mike posted this 29 December 2017
You want to change Limits.MaxPlayers in McMyAdmin.conf as well as Server.Properties.
Vilzu45 posted this 31 December 2017
So do i need to change the player amount in both of the files?
Mike posted this 31 December 2017
Yes.
Close
