I've purchased a McMyAdmin Pro license but it doesn't seem to apply
  • 626 Views
  • Last Post 13 July 2019
  • Topic Is Solved
dpd26 posted this 25 May 2019
OS Name/Version: Ubuntu Server 18.04 LTS
Product Name/Version: McMyAdmin 2.7.1.0
Problem Description: I try to apply the license, it says successful, log out and back in again but it still shows as being the personal version in "About"
Steps to reproduce: Add the license key Recieve successful message Log out, and back in again
Actions taken to resolve so far: Applied key and rebooted McMyAdmin, and whole OS.
I also don't seem to be able to use any pro features so it appears as though the license doesn't apply
  • Liked by
  • killertunes
Mike posted this 27 May 2019
Try reactivating on the command line.
You can reactivate a McMyAdmin 2 install by opening a command prompt in it’s install directory and running ./MCMA2_Linux_x86_64 +mcmyadmin.licencekey YOURKEYHERE -configonly - same applies for Windows, just replace ./MCMA2_Linux_x86_64 with McMyAdmin.exe.
  • Liked by
  • killertunes
killertunes posted this 13 July 2019
Thank you so much for that! Had same exact issue as the OP.
Close
