No connection to instances after 1.8.5.0
  • 226 Views
  • Last Post 08 September 2019
  • Topic Is Solved
Das_Pflanze posted this 07 September 2019
Hello everyone,
after updating to 1.8.5.0 I can't connect to instances anymore. After logging in to the main instance I see my Minecraft01 instance under "local instances" and I'm able to start, update and stop it. But when I click on "manage" I see the loading screen with "Connecting to remote AMP instance..." and a endless loading spinner.
Log of ADS01:
[19:40:58] [Auth:Anonymous Activity] : Authentication attempt for user admin from 172.17.0.1
[19:40:58] [Auth:admin Activity]  : Authentication success
[19:41:01] [ADS:admin Activity]   : Managed remote instance Minecraft01 at http://localhost:8081/
[19:41:01] [Auth:admin Activity]  : Authentication token for admin requested by ManageInstance on behalf of admin
[19:51:28] [ADS:Anonymous Error]  : Failure to make API call to Minecraft01 (http://localhost:8081/) - retried 10 times : The operation was canceled.
[19:51:28] [Core:Anonymous Error] : [0] (TaskCanceledException) : The operation was canceled.
[19:51:28] [Core:Anonymous Error] :   at ADSModule.WebMethods.Servers (m.Http.IHttpRequest request, String id, String REQ_RAWJSON)
[19:51:28] [Core:Anonymous Error] : [1] (ObjectDisposedException) : Cannot access a disposed object.
Object name: 'System.Net.Sockets.NetworkStream'.
[19:51:28] [Core:Anonymous Error] :   at Net.Sockets.NetworkStream.EndRead (IAsyncResult asyncResult)
  at IO.Stream+<>c.<beginendreadasync>b__45_1 (IO.Stream stream, IAsyncResult asyncResult)
  at Net.Http.HttpConnection.FillAsync ()
  at Net.Http.HttpConnection.ReadNextResponseHeaderLineAsync (Boolean foldedHeadersAllowed)
[19:57:42] [ADS:Anonymous Error]  : Failure to make API call to Minecraft01 (http://localhost:8081/) - retried 10 times : The operation was canceled.
[19:57:42] [Core:Anonymous Error] : [0] (TaskCanceledException) : The operation was canceled.
[19:57:42] [Core:Anonymous Error] :   at ADSModule.WebMethods.Servers (m.Http.IHttpRequest request, String id, String REQ_RAWJSON)
[19:57:42] [Core:Anonymous Error] : [1] (ObjectDisposedException) : Cannot access a disposed object.
[19:57:42] [Core:Anonymous Error] :   at Net.Sockets.NetworkStream.EndRead (IAsyncResult asyncResult)
Log of Minecraft01: https://pastebin.com/FEqP27jc
Mike posted this 08 September 2019
The Minecraft instance can't reach the auth server. Check that the url in AMPConfig.conf is valid for the auth server URL and is responding.
Das_Pflanze posted this 08 September 2019
Hi Mike,
thank you very much, that solved my problem! It seems like the update removed my custom auth server URL.
Close
