Not able to use instance Controller to manage instances
  • 111 Views
  • Last Post 03 February 2019
  • Topic Is Solved
XXdaugonXX posted this 03 February 2019
OS Name/Version: Distributor ID: Debian Description: Debian GNU/Linux 9.7 (stretch) Release: 9.7 Codename: stretch
Product Name/Version: AMP Instance Manager v1.7.2.4 built 17/01/2019 14:20
Problem Description: for some reason I cant use the instance controller to connect to instances and it just gives an error in the console
Files Instances.json: https://pastebin.com/fwNvypAx ADS01 config: https://pastebin.com/e2CjXNqy Game Instance config: https://pastebin.com/XX2ARxkP Console Error: https://pastebin.com/3aqknMKS
Mike posted this 03 February 2019
Are the instances themselves set up as https? I'd recommend that the instances just run as straight HTTP and you firewall them out if you're using ADS.
Okay ill do that I was just wondering if it was possible to do it the other way because I can see the controller try to connect through the localhost IP to them
Close
