Plugins doesn't work!
  • 125 Views
  • Last Post 18 July 2019
  • Topic Is Solved
Nobody posted this 17 July 2019
Is mcmyadmin actually supporting plugins? I tried to add "SetHome 4.0" in the plugins-folder and it shows as enabled under Plugins, but the plugin does'nt seem to work.
Do i have to do something else in mcmyadmin before the plugin can work?
Mike posted this 18 July 2019
You need to use Craftbukkit or Spigot to have plugins, the standard 'vanilla' server doesn't support them.
Nobody posted this 18 July 2019
Thank you for the informative answer. Is it enough that i just select Craftbukkit in the dropdown menu?
You have to hit Update so it actually downloads it.
  • Liked by
  • Nobody
Of course, i knew that. hahaha! Thanks for all the help and for your quick reply.
Close
