setup problems
  • 361 Views
  • Last Post 20 August 2019
  • Topic Is Solved
WillRaasch posted this 15 August 2019
OS Name/Version: centos 7
Product Name/Version: AMP
Problem Description: pastebin
Mike posted this 15 August 2019
Are you able to ping google.com as your AMP user?
Yes just tried. https://pastebin.com/8FMdSt4h
Here you go
ip addr
ping -6 google.com
Can you post the outputs of both:
ip addr
And:
ping -6 google.com
Here you go
Here you go
ip addr
ping -6 google.com
Interesting. Are you able to wget cubecoders.com? Also who is the hosting provider?
I downloaded the program AMP using wget cubecoder.com. I am hosting this server box at my house and it is att fiber.
Mike posted this 16 August 2019
Okay, can you try running the quickstart again please?
WillRaasch posted this 16 August 2019
Sorry for the delayed answer quickstart and I can ping google.
Mike posted this 17 August 2019
Can you delete the AMPCache files please in the datastore directory and try again.
WillRaasch posted this 17 August 2019
I deleted this file
/home/AMP/.ampdata/instances/AMPCache-1834.zip
then ran the quickstart and got this in console
I think your IPv6 may be misconfigured, can you disable it temporarily and try again?
That worked but now it's telling to go to 192.168.1.64:8081 and no matter which browser I try it won't connect. I have used Chrome Internet Explorer Edge and firefox.
You may need to adjust your firewall rules to allow that port through first. By default it opens 8080
I had both 8080 and 8081 added and port forwarded, because I have mcmyadmin running one minecraft server on port 8080
Mike posted this 18 August 2019
Not port forwarded, allowed through the local firewall.
WillRaasch posted this 18 August 2019
I did add it to my centos firewall
enter image description here
https://i.gyazo.com/2d84039ba89c574435883598740dd187.png
Mike posted this 19 August 2019
There's a known issue with CentOS - please see https://github.com/CubeCoders/AMP/wiki/Common-known-AMP-Issues
Show More Posts
Close
