A problem with modifying config.ini
  • 17 Views
  • Last Post 2 weeks ago
Qblolz posted this 2 weeks ago
Hello, I have some issue with modifying config.ini for factorio server. Every time after run server - config file will reset to default. How I can avoid this and add custom configuration arguments.
Mike posted this 2 weeks ago
What game is this for? AMPs configuration handing is write only so generally you must edit settings via AMP itself.
Need add this configuration variant for compress save files. Factorio - its game - have some problem with too big save file - every1 who want connect to server need download map - map can be 200mb+ - compress will be decrease size
; Options: fast, maximum
multiplayer-compression-level=fast
; Options: none, fast, maximum
autosave-compression-level=fast
Factorio have too many issues about map size - check in google with search query "autosave-compression-level=fast factorio"
Close
