ADS instance will not start after updating to AMP 2.0.6
  • 116 Views
  • Last Post 21 August 2020
kprose posted this 21 August 2020
OS Name/Version:
 Windows Server 2019 Datacenter (Desktop Experience) Build 1809
Product Name/Version:
 AMP v2.0.6
I updated ADS to version 2.0.6.0 and now it looks like it hangs while starting. The only other thing I changed was I updated from Java 8 to Java 11 but I could restart and it would work just fine before the AMP update.
Before Update: https://pastebin.com/xzdAi1rU
After Update: https://pastebin.com/1VyzrNNF
1. Update to 2.0.6
I have restarted the server, toggled the instance between not being a service and being a service.
Mike posted this 21 August 2020
Reboot
I did that, 10 times now. I checked Event Viewer, nothing. I tried to switch to the Nightly build to see if anything changed, nothing, so I switched it back to Mainstream. I also did your suggestion on another post to run upgradeall --nocache
Turn on debug logging: https://github.com/cubecoders/amp/wiki/Diagnosing-AMP-issues
Here is the log after enabling all debugging settings (Monitoring.LogLevel=0, Monitoring.ProduceStartupScripts=True, Security.LogSensitiveProcArgs=True). I do not see any other logs anywhere in the datastore as mentioned by the documentation https://pastebin.com/u9RnX1x5
Close
