Backups in Minecraft module are extracted into wrong directory
  • 95 Views
  • Last Post 25 May 2018
fenriv posted this 23 May 2018
OS Name/Version: Debian 9.4
Product Name/Version: AMP Beta 'TN/SR5' 1.6.8.0 Minecraft module ForgeMod server installed from AMP configuration for Minecraft (14.23.3.1655 mc 1.12.2)
Problem Description: Backup are restored to a subdirectory of minecraft server directory. Instance dir: ~/.ampdata/instances// Minecraft dir: ~/.ampdata/instances//Minecraft Backup restore dir: ~/.ampdata/instances//Minecraft/MinecraftModule As result, restoring of a backup is having no effect on the instance.
Steps to reproduce: 1. Create new backup 2. Go to backups and press "Restore Backup"
Expected result: MC server state is restored to the point of a time when the backup was taken (and current state is moved to ./trash subdir).
Actual result: MC server state remaining as it was before restoring the backup.
Actions taken to resolve so far: SSH to server and move files from MinecraftModule dir to one directory higher in hierarchy.
fenriv posted this 25 May 2018
Had a little of time to look at the root of the issue and here's what I have found.
Inside LocalFileBackupPlugin in class BackupProvider there are two methods TakeBackup and RestoreBackup.
TakeBackup method is appending the ModuleName property value to the directory path in archive variable:
var directoryPathInArchive = ... ? manifest.ModuleName : Path.Combine(manifest.ModuleName, fileInfo.Directory.FullName.Substring(directoryInfo.FullName.Length));
while RestoreBackup is just running extraction:
zip.ExtractAllAsync(this.SourcePath, ExtractExistingFileAction.OverwriteSilently, task);
where SourcePath is
this.SourcePath = this.settings.Storage.OverrideOriginDirectory ? this.settings.Storage.OriginDirectory : app.BaseDirectory
The code is generated, but should be close to what actually going on within the assembly. I hope this helps with an investigation.
Cheers.
Mike posted this 25 May 2018
Thanks I will look into it.
Close
