Forge not starting after download every java known to man!
  • 50 Views
  • Last Post 2 weeks ago
HPHayblood posted this 2 weeks ago
In order to get the server to start, I tried Java SRE/JDK 86/64/32bit 7 through Java 16.
A problem installing the server was detected, server install cannot continue 01:24:21 Setting up logger: B:\AMP\Instances\ALLMODS3\Minecraft\forge-1.12.2-14.23.5.2768-installer.jar.log java.net.preferIPv4Stack=true
Installing server to current directory
A problem installing the server was detected, server install cannot continue Console01:24:30 Setting up logger: B:\AMP\Instances\ALLMODS3\Minecraft\forge-1.12.2-14.23.5.2768-installer.jar.log java.net.preferIPv4Stack=true Option Description
--extract Extract the contained jar file -h, --help Help with this installer --installServer Install a server to the current directory --offline Don't attempt any network calls
Setting up logger: B:\AMP\Instances\ALLMODS3\Minecraft\forge-1.12.2-14.23.5.2768-installer.jar.log Option Description
java.net.preferIPv4Stack=true ------ -----------
[01:22:27] [System Warning]       : Server failed to start 1/5 times... [01:22:27] [System Warning]       : Server stopped within 5 seconds of starting, AMP will not attempt to restart it. --extract Extract the contained jar file -h, --help Help with this installer
--offline Don't attempt any network calls [01:22:27] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected A problem installing the server was detected, server install cannot continue [01:22:27] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected [01:22:27] [APIService Warning]   : 127.0.0.1 tried to use session ID 2379aebf-d706-4c44-a9fa-c0d80ec8671c - but no such ID exists and session remapping is not enabled without Passthru Auth. [01:22:27] [Core:Anonymous Activity] : Authentication attempt for user admin from 127.0.0.1 [01:22:27] [APIService Warning]   : 127.0.0.1 tried to use session ID 2379aebf-d706-4c44-a9fa-c0d80ec8671c - but no such ID exists and session remapping is not enabled without Passthru Auth. [01:22:27] [Core:Anonymous Activity] : Authentication attempt for user admin from 127.0.0.1 [01:22:27] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected [01:22:27] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected [01:22:27] [APIService Warning]   : 127.0.0.1 tried to use session ID 2379aebf-d706-4c44-a9fa-c0d80ec8671c - but no such ID exists and session remapping is not enabled without Passthru Auth. [01:22:27] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected [01:22:27] [APIService Warning]   : 127.0.0.1 tried to use session ID 2379aebf-d706-4c44-a9fa-c0d80ec8671c - but no such ID exists and session remapping is not enabled without Passthru Auth. [01:22:27] [Core:Anonymous Activity] : Authentication attempt for user admin from 127.0.0.1 [01:22:27] [Core:Anonymous Activity] : Authentication attempt for user admin from 127.0.0.1 [01:22:27] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected [01:22:27] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected [01:22:27] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected [01:22:28] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected [01:22:28] [Core:Anonymous Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected [01:23:09] [Core:Anonymous Activity] : Authentication attempt for user admin from 127.0.0.1 [01:23:09] [Core:Anonymous Activity] : Authentication success [01:24:20] [System:admin Activity] : Updating the application. Setting up logger: B:\AMP\Instances\ALLMODS3\Minecraft\forge-1.12.2-14.23.5.2768-installer.jar.log java.net.preferIPv4Stack=true Installing server to current directory A problem installing the server was detected, server install cannot continue [01:24:30] [System:admin Activity] : Starting the application. [01:24:30] [Minecraft:admin Info] : Java located at C:\Program Files\Java\jre1.8.0_301\bin\java.exe [01:24:30] [Minecraft:admin Info] : Using 'Forge' compatibility mode. Setting up logger: B:\AMP\Instances\ALLMODS3\Minecraft\forge-1.12.2-14.23.5.2768-installer.jar.log java.net.preferIPv4Stack=true Option Description
--offline Don't attempt any network calls [01:24:30] [System:admin Warning] : Server failed to start 2/5 times... [01:24:30] [System:admin Warning] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it. [01:33:20] [System:admin Activity] : Downloaded file logs/latest.log (API mode) [01:33:29] [System:admin Activity] : Downloaded file logs/2021-09-06-3.log.gz (API mode)
Diagnostics Data Field Value OS Windows Platform Microsoft Windows Server 2016 Datacenter System Type x86_64 Virtualization None Module ADSModule Loaded Plugins FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin Application Name AMPService Application Version 2.2.0.6 Release Stream Release Build Date 23/08/2021 13:35 InstanceID 1019ea53-b936-44e8-af64-00151602a38e Last Executable B:\AMP\Instances\ALLMODS3\AMP.exe Last Arguments +Core.Webserver.Port "8082" +Core.Webserver.IPBinding "0.0.0.0" +FileManagerPlugin.SFTP.SFTPPortNumber "2225" +MinecraftModule.Minecraft.PortNumber "25565" Last Process ID 9936
Mike posted this 2 weeks ago
You're running the installer, not the actual server. Either have AMP do the install, or run the installer yourself locally and then upload the resulting server to AMP.
Close
