Fresh Nightly 1.7.0.0 installed on fresh Ubuntu 16.04 - Error on login
  • 964 Views
  • Last Post 20 May 2018
  • Topic Is Solved
ponack posted this 20 May 2018
Hello, I just loaded AMP on a new server and with a new ADS instance and trying to login I get the following error:
Invalid salt Parameter name: salt
Thrown by the 'Core' plugin while performing the 'Login' method.
Any assistance would be greatly appreciated! Thank you!
Mike posted this 20 May 2018
https://support.cubecoders.com/thread/known-amp-issues-check-here-before-posting/
It's a known issue, you need to use the command line to reset the login details and it'll work.
  • Liked by
  • ponack
Thanks Mike, I thought I tried that but I must have did something wrong, it's all set now. Take care!
Close
