FTB Continuum 1.0.2 on AMP 1.6.8.0: Many recipes do not work while running server with AMP
  • 154 Views
  • Last Post 19 May 2018
  • Topic Is Solved
Wombat posted this 18 May 2018
OS Name/Version: Windows 10, April Update
Product Name/Version: AMP 1.6.8.0 with a McMyAdmin key, Minecraft 1.12.2, FTB Continuum 1.0.2
Problem Description: Many recipes do not work on FTB Continuum 1.0.2 server running via a fresh AMP 1.6.8.0 installation. Recipes work as expected when running server via the included ServerStart.bat.
1) Create and run new AMP instance using default settings
2) Install new FTB Continuum 1.0.2 server using default settings.
3) Run server using ServerStart.bat.
4) Log in and discover that many recipes work as expected.
5) Save and stop server.
6) Run server using AMP.
7) Log in and discover that many recipes do not work as expected.
* Delete server files and install fresh server files * Delete instance
* Uninstall/Reinstall AMP
* Uninstall/Reinstall Java
* Restart computer
ServerStart.bat: https://pastebin.com/0tuRMk1Q
settings.bat: https://pastebin.com/DgiZ1XeL
Please let me know if there's anything else I can provide to help. Thanks!
Mike posted this 19 May 2018
Issue was resolved on Discord, turned out to be a file permissions issue.
Close
