FTP write errors using external FTP client
  • 106 Views
  • Last Post 09 July 2020
Dark posted this 09 July 2020
Hello,
I was trying to edit the config.yml for Grief Prevention on one of my Minecraft instances running Spigot.
Using MobaXTerm, I was editing the file using VSCode and turned autosave (on Ctrl + S) on for MobaXTerm. I also tried with pressing "yes" on the prompt everytime.
What ended up happening was the following: https://github.com/TechFortress/GriefPrevention/issues/877#event-3527929101
It was appending random values, like \n : false or s: false to the end of the file. After some trial and error, I decided to use the web client's File Manager editor, and turns out it works fine.
However, it only caused this problem on a certain server I had. On a fresh instance with no other modifications, the write was fine.
Just wanted to report this, since it seems like a bug with AMP.
Mike posted this 09 July 2020
What happens if you use a dedicated FTP client such as Filezilla or WinSCP?
Close
