Hilfe Help
  • 141 Views
  • Last Post 27 June 2019
sklavePhoenix posted this 19 June 2019
hallo seit dem update geht nichts mehr, wie kann ich eine ältere intalation ausführen ? ich kann keine Instanzen mehr starten und sehe nichtsmehr in der Console und nun ist das Panel nichtmehr zu erreichen . ich müsste eine komplette neuinstalation ausführen jedoch finde ich nichts über ein uninstall können sie mir helfen ?
hello since the update is nothing more, how can I run an older intalation? I can not start any more instances and see nothing more in the console and now the panel is no longer reachable. I would have to perform a complete reinstallation however I can not find anything about an uninstall can they help me?
Mike posted this 19 June 2019
Hi, if you've just updated you probably need to press CTRL+F5 in your browser to empty the cache.
Also make sure the instances are starting using ampinstmgr startall - if they are not running after that check their log files to see if there's anything wrong.
AMP cannot be downgraded so we'll need to figure out what's up.
  • Liked by
  • sklavePhoenix
The problem is that I can not log in more than once although I have installed everything and I have to uninstall it and completely reinstall And I would need help
Mike posted this 20 June 2019
Have you checked the instances log files to see if they're able to start? Also check the output of ampinstmgr table
  • Liked by
  • sklavePhoenix
sklavePhoenix posted this 20 June 2019
So nothing comes out for me I have to reinstall the whole webinterface and I would have to uninstall it for that and I need help because I do not know how to do it
sklavePhoenix posted this 22 June 2019
can nobody help me ? I have paid for the webinterface and can not use it
Mike posted this 27 June 2019
Hi, have you installed the latest updates? The recent release addressed some common issues.
Close
