I've ran a modded server with the Minecraft server JAR utility and forge for a little while now and I've found Mcmyadmin. I want to incorporate in to my experience but I've been having problems with an error stoping everything from working. It says something about "x is not valid option" after running Optifine and a few other things. i've tried running it with -o in the config but it still says that o is an invalid option too.
I need help starting a dedicated Minecraft 1.16.5 modded server.
- 134 Views
- Last Post 4 weeks ago
- Topic Is Solved
Mike
posted this
4 weeks ago
McMyAdmin is no longer supported, it has been replaced by AMP as per the orange banner on the McMyAdmin website.
Doominuke
posted this
4 weeks ago
Ah, I see. I must have gotten carried away, sorry about that. Well, does AMP do all the same things that Mcmyadmin said it would do?
Magesw
posted this
4 weeks ago
Even though AMP is the current thing McMyAdmin will run the 1.16.5 server just fine. However you can get AMP and use your McMyAdmin key. AMP has more features.
Doominuke
posted this
4 weeks ago
Great! I've tried out AMP and I've gone through the steps, but I'm curious about the licences. Am I required to buy a licence or can I just run one instance without one? I don't necessarily need 5 licenses and I wouldn't mind paying for this sort of program if it wasn't like I was buying 5 of them.
