Instances using TCP+UDP duplicating UDP rules instead
  • 112 Views
  • Last Post 3 weeks ago
  • Topic Is Solved
AbhorrentJoel posted this 05 February 2021
OS Name/Version: Ubuntu 20.04.2 LTS (fresh install since a few days)
Product Name/Version: AMP (apt version 2.1.0.2 - upgraded from 2.1) - NOTE: I am using Docker for instances, but it seems to occur regardless.
Problem Description: When creating a new instances, AMP appears to be duplicating UDP ports in the case where TCP+UDP is specified.
I have two instances created, for Minecraft and 7 Days to Die, and the port is duplicated - 4 bottom rules:
root@[redacted]:~# ampinstmgr dumpports amp
[Info] AMP Instance Manager v2.1.0.2 built 03/02/2021 00:33
[Info] TCP/2223 (AMP:ADS01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info] UDP/12820 (AMP:ADS01:ADSModule.Network.MetricsServerPort)
[Info] TCP/2224 (AMP:Minecraft01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info] TCP/2225 (AMP:SevenDays01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info] TCP/8766 (AMP:SevenDays01:SevenDaysModule.Server.WebServicePort)
[Info] TCP/27016 (AMP:SevenDays01:SevenDaysModule.Server.TelnetPort)
[Info] UDP/25565 (AMP:Minecraft01:MinecraftModule.Minecraft.PortNumber)
[Info] UDP/27015 (AMP:SevenDays01:SevenDaysModule.Server.ServerPort)
For example, the output from the firewall for the 7 Days to Die instance:
root@[redacted]:~# ufw status numbered | grep SevenDays01
[ 8] 2225/tcp                   ALLOW IN    Anywhere                   # AMP:SevenDays01:FileManagerPlugin.SFTP.SFTPPortNumber
[ 9] 8766/tcp                   ALLOW IN    Anywhere                   # AMP:SevenDays01:SevenDaysModule.Server.WebServicePort
[10] 27016/tcp                  ALLOW IN    Anywhere                   # AMP:SevenDays01:SevenDaysModule.Server.TelnetPort
[11] 27015/udp                  ALLOW IN    Anywhere                   # AMP:SevenDays01:SevenDaysModule.Server.ServerPort
[22] 2225/tcp (v6)              ALLOW IN    Anywhere (v6)              # AMP:SevenDays01:FileManagerPlugin.SFTP.SFTPPortNumber
[23] 8766/tcp (v6)              ALLOW IN    Anywhere (v6)              # AMP:SevenDays01:SevenDaysModule.Server.WebServicePort
[24] 27016/tcp (v6)             ALLOW IN    Anywhere (v6)              # AMP:SevenDays01:SevenDaysModule.Server.TelnetPort
[25] 27015/udp (v6)             ALLOW IN    Anywhere (v6)              # AMP:SevenDays01:SevenDaysModule.Server.ServerPort
Obviously, this results in it being impossible to connect where TCP is required. I have a feeling that it worked in AMP v2.1, yet I cannot confirm.
  • Install AMP v2.1 (with Docker) on a fresh Ubuntu 20.04.2 LTS install
  • Upgrade to AMP v2.1.0.2
  • Create instances for games which use TCP+UDP (7 Days to Die, Minecraft, etc.)
  • Forced an upgrade of AMP instances using no-cache option
  • Removed ampinstmgr apt package, cleaned apt cache, and reinstalled
  • Deleted and created new instances
AbhorrentJoel posted this 4 weeks ago
Fixed in v2.1.0.6. Mentioned here.
Painwithin posted this 3 weeks ago
This issue still seems to be apparent in 2.1.0.6 mine was working fine until updating now its duplicating UDP on ports "mainly game server ports".
AbhorrentJoel posted this 3 weeks ago
It was working fine for me after the update to 2.1.0.6. I am not sure if it is necessary to create new instances in order for this to work - I would have guessed not, but cannot confirm.
Just ensure you have updated ampinstmgr via your distro's package manager, and preferably update AMP instances using the nocache option:
ampinstmgr --nocache upgradeall
I am currently on the Nightly build due to fixes applied to the Generic module, but it is seemingly all working fine for me there.
Close
