Low number port
  • 3.9K Views
  • Last Post 05 April 2018
  • Topic Is Solved
digger4cc posted this 02 April 2018
New user, new poster. Basics:
Ubuntu 16.04 64-bit
Oracle JRE/JDK 1.8
Vanilla minecraft 1.12.2
Using port 995 via privbind
I have full access to the server. I am looking to move to McMyAdmin v2. I understand that I can move my existing vanilla server files into the Mincraft folder under the MCMA user dir. I am using port 995 for several reasons based on the environment where I am hosting the server. Is there a way to either customize the startup in MCMA to use privbind or another way to use privileged port 995?
Mike posted this 03 April 2018
Recommended way is to actually run it on a higher port and use iptables to redirect the desired lower port to the higher one.
digger4cc posted this 03 April 2018
Thanks, I was considering something similar. Did not know if there was a more direct method.
Mike posted this 05 April 2018
Not really, AMP doesn't like running with any kind of elevated permissions.
Close
