Minecraft not starting on fresh installation
  • 102 Views
  • Last Post 25 January 2021
kontraproduktiv posted this 25 January 2021
Fresh install of AMP with the Script provided on the website.
When trying to start a Minecraft server it gives the following in the logs:
[16:39:50] [Core Warning]         : Unrecognised argument: 127.0.0.1 +filemanagerplugin.sftp.sftpportnumber. See -help for arguments list.
[16:39:50] [Core Warning]         : Unrecognised argument: 2224 +minecraftmodule.minecraft.portnumber. See -help for arguments list.
[16:39:50] [Core Warning]         : Unrecognised argument: 23000. See -help for arguments list.
[16:39:50] [Core Info]            : Running in a QEMU KVM environment.
[16:39:50] [Core Warning]         : Current time zone is set to CET - Servers should ideally be UTC to avoid time-zone related issues
[16:39:50] [Core Info]            : OS: Linux / x86_64
[16:39:50] [Core Info]            : CPU: AMD EPYC 7702P 64-Core Processor (2C/2T)
[16:39:50] [Core Info]            : AMP Instance ID: 44a682ed-760f-4033-b5d3-e5405e183234
[16:39:51] [ModuleLoader Info]    : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[16:39:51] [Core Info]            : Metrics publishing is enabled at udp://localhost:12820.
[16:39:51] [ModuleLoader Info]    : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[16:39:51] [ModuleLoader Info]    : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[16:39:51] [ModuleLoader Info]    : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[16:39:52] [ModuleLoader Info]    : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[16:39:52] [ModuleLoader Info]    : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[16:39:52] [Core Error]           : Unable to set Core.Webserver.Port (Int32) to 8081 +Core.Webserver.IPBinding
[16:39:52] [Core Error]           : Input string was not in a correct format.
[16:39:52] [Core Info]            : Licence Present: AMP Professional Edition (Licenced to Christian Wieden)
[16:39:52] [FileManager Notice]   : No SSH keypair available for embedded server, generating new keypair...
[16:39:52] [FileManager Notice]   : Generated new keypair with fingerprint
[16:39:52] [FileManager Notice]   : Using keypair with fingerprint
[16:39:52] [FileManager Info]     : SFTP Server started on 0.0.0.0:2224
[16:39:52] [WebServer Info]       : Websockets are enabled.
[16:39:52] [WebServer Info]       : Webserver started on 127.0.0.1:8081
[16:39:52] [Logger Warning]       : RouterTimer@10Hz with 2 jobs started
[16:39:52] [Core Info]            : Checking for AMP updates...
[16:39:52] [Core Info]            : AMP is up-to-date.
And no port is opened to connect.
Mike posted this 25 January 2021
You've started the instance, but not the server. Please see this tutorial:
to video
Close
