MultiWorld Help
  • 139 Views
  • Last Post 05 February 2018
splash5 posted this 15 January 2018
OK I'm new to this i got the server setup but i would love multi world use, what plugin do i need to use? i would only like to use this from my in home family setup.
ashlyne posted this 05 February 2018
It depends on what you mean by "multi-world use". If you mean just extra worlds for a minecraft server, then the internet for a good multi-world plugin. This isn't exactly the place to get suggestions for plugins. However, if you mean a multi server setup (Linking AMP instances together to make one minecraft server), you are going to need to spigot for the minecraft instances and then also setup a bungeecoord instance which links them together.
Close
