noob need help installing instances
  • 108 Views
  • Last Post 11 November 2017
tizzom posted this 11 November 2017
i got amp installed and im in the control panel. im assuming i need to install the minecraft module at the very least to run a server. when i install it it remains red and wont start. i think i need to use the ip address of my server in AMP IP binding option and IP binding option, or am i wrong? im trying to run multiple ftb servers. do i need to install the mcmyadmin module as well? thanks for any help
Mike posted this 11 November 2017
Did you make sure to give that instance it's own port number? You can check that instances log to see what's up.
Close
