Problem/Error Installing
  • 77 Views
  • Last Post 12 August 2017
Magino188 posted this 12 August 2017
Log:
[Info] Waiting...
[Info] Licence Type:  AMP Professional
[Info] Current Usage: 0
[Info] Creating Instance: 'System'
[Debug] Running command line: "useradd -m -s /bin/false -c "AMP User for service System" -- AMPUSER-System" from "/"
The IP address and port combination is already in use by another instance.
[Error] Instance creation failed.
[Error]   at System.Threading.Tasks.Task.ThrowIfExceptional (System.Boolean includeTaskCanceledExceptions) [0x00011] in <3574b7750bbd4f3481d1561b74d01b33>:0
  at System.Threading.Tasks.Task`1[TResult].GetResultCore (System.Boolean waitCompletionNotification) [0x0002b] in <3574b7750bbd4f3481d1561b74d01b33>:0
  at System.Threading.Tasks.Task`1[TResult].get_Result () [0x0000f] in <3574b7750bbd4f3481d1561b74d01b33>:0
  at InstanceManagerCLI.Core.CreateInstance (System.String Module, System.String InstanceName, System.String IPBinding, System.Int32 PortNumber, System.String LicenceKey, System.String AdminPassword, System.Collections.Generic.Dictionary`2[TKey,TValue] ProvisionSettings) [0x002c3] in <be7b58e6762c4462976bef94987be459>:0
[Info] Checking licence key...
[Info] Waiting...
[Info] Creating Instance: 'ADS-System'
[Info] Performing Step: Creating Environment
[Debug] User: AMP
[Debug] Home Dir: /home/AMP
[Info] Performing Step: Downloading AMP
[Debug] User: AMP
[Info] Downloading AMP...
[Info] Complete
[Info] Performing Step: Unpacking
[Debug] Running command line: "unzip -qq -o "/home/AMP/.ampdata/instances/AMPCache-1480.zip"" from "/home/AMP/.ampdata/instances/ADS-System"
[Debug] Starting process /bin/uname
[Debug] Working Directory: /root/AMP
[Debug] Arguments: -m
[Debug] Started process with ID 18817
[Error] Download or unpack failed. Please check your network connection and try again.
[Debug] Started process with ID 18818
[Error] AMP_Linux_Unknown does not exist!
[Info] Performing Step: Failed
[Info] Instance creation failed.
</be7b58e6762c4462976bef94987be459></3574b7750bbd4f3481d1561b74d01b33></3574b7750bbd4f3481d1561b74d01b33></3574b7750bbd4f3481d1561b74d01b33>
Mike posted this 12 August 2017
it says right there what's wrong:
Use a different IP/port combo :P
Also don't run ampinstmgr as root - follow the installation instructions fully please.
Close
