Problem with compiling Spigot server jar
  • 165 Views
  • Last Post 12 February 2018
TKAndy posted this 11 February 2018
Tried changing my Minecraft server from vanilla to Spigot today but can't seem to get it to compile the server jar. The only error that shows up on the status site is "Unable to start server. The update manager reported a successful update, but ./Minecraft/spigot.jar is missing." Any known fixes for this?
Mike posted this 11 February 2018
Check the buildtools logs, see if there's any issues. Make sure if you're on Windows that the datastore isn't located in an Administrators AppData directory.
I'm running windows yes! But can't seem to find any datastore in AppData. The log show this: "
Rebuilding Forked projects....
HEAD is now at 70afb21e SPIGOT-3807: Improve getEyeHeight
Resetting Spigot-API to Bukkit...
  Applying patches to Spigot-API...
fatal: Resolve operation not in progress, we are not resuming.
Applying: POM Changes
error: Your local changes to the following files would be overwritten by merge:Using index info to reconstruct a base tree...
    pom.xmlFalling back to patching base and 3-way merge...
Please commit your changes or stash them before you merge.Patch failed at 0001 POM Changes
AbortingThe copy of the patch that failed is found in: .git/rebase-apply/patch
error: Failed to merge in the changes.When you have resolved this problem, run "git am --continue".
If you prefer to skip this patch, run "git am --skip" instead.
To restore the original branch and stop patching, run "git am --abort".
  Something did not apply cleanly to Spigot-API.
  Please review above details and finish the apply then
  save the changes with rebuildPatches.sh
Error compiling Spigot. Please check the wiki for FAQs.
If this does not resolve your issue then please pastebin the entire BuildTools.log.txt file when seeking support.
java.lang.RuntimeException: Error running command, return status !=0: [sh, applyPatches.sh]
    at org.spigotmc.builder.Builder.runProcess0(Builder.java:639)
    at org.spigotmc.builder.Builder.runProcess(Builder.java:597)
    at org.spigotmc.builder.Builder.main(Builder.java:478)
    at org.spigotmc.builder.Bootstrap.main(Bootstrap.java:23)
" I dont know what to make of this tho.
It's a bug in buildtools then, you should give that log to the Spigot guys and ask what's up.
  • Liked by
  • TKAndy
Ah, then I'll do that! Thanks!
TKAndy posted this 12 February 2018
For future use. The problem with me was that I had installed 64-bit Git. Removed and installed 32-bit and Spigot compiled succesfully!
Close
