Problems with McmyAdmin3/Minecraft
  • 136 Views
  • Last Post 01 January 2019
Corradodave posted this 01 January 2019
Hi, i installed AMP on a fresh Debian Maschine.
Amp is Running Fine, if i add a new Instance (Minecraft Java) it going Green and after 10 Seconds it change to Red Not Running. No Errors
01.01.2019 21:03:51 Using cached archive: /home/AMP/.ampdata/instances/AMPCache-1700.zip
21:04:06 Waiting for AMP
instance to start...
21:04:07 AMP instance Minecraft01 is now running.
Field   Value
OS  Linux
Platform    Linux Debian-94-stretch-64-minimal 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux
System Type x86_64
Virtualization  None
Module  ADSModule
Loaded Plugins  EmailSender, FileManager, PushBulletPlugin, LocalFileBackupPlugin
Application Name    AMP
Application Version 1.7.0.0
Release Stream  Release
Build Date  21/12/2018 01:55
InstanceID  870a0b9d-2b23-486a-89d5-22a4b1524605
Last Executable /usr/bin/tmux
Last Arguments  -f /dev/null new-session -s "AMP_Minecraft01" -d "cd '/home/AMP/.ampdata/instances/Minecraft01'; /home/AMP/.ampdata/instances/Minecraft01/AMP_Linux_x86_64 "
So what can i do`?
I solved the problem..
my McmyAdmin2 Pro Key didnt work for this, i buy a new amp key, now the instance is running fine
Close
