Rebinding Instances is not possible
  • 160 Views
  • Last Post 04 December 2017
  • Topic Is Solved
FlayInAHook posted this 03 December 2017
Since its a long time problem now that rebinding instances is not possible I decided to post the problem here.
So I just want to quickly rebind all of my web interfaces because I got a 2nd IP. But Its simply not possible. The quintessence of the log says "The IP address and port combination is already in use by another instance." nevertheless, I posted the whole exception here. I have the following setup for my instances setup and I want to issue this command ./ampinstmgr --RebindInstance EHGMC 138.201.145.230 25577 but it doesn't let me. I also tried ./ampinstmgr --RebindInstance EHGMC 138.201.145.230 25578 this before the other command to avoid the same port but it didn't work. Stopping all instances before didn't help either. I know that I could edit every config file of the web interfaces but this would cost me so much time. I hope you can fix this :)
Mike posted this 03 December 2017
What's the output of ./ampinstmgr -l ?
FlayInAHook posted this 04 December 2017
instances setup
Here you can find it
Mike posted this 04 December 2017
Well it's behaving correctly. You've got another instance on that same port number bound to every IP address (0.0.0.0)
You'd have to rebind that instance to a specific IP address or use a different port.
But I did this with the commands? I'd even rebinded it to another port before to prevent such behavior.
The instance called EHGMC is already bound to 25577 (so it won't let you rebind to the same port) and LeonardFamilie is using port 25578.
my dumbness has no boundaries.. thx for the help :)
Close
