Space Engineers: Mods issue, Store Settings Issues
  • 305 Views
  • Last Post 3 weeks ago
Gothyk posted this 17 May 2019
So, I'm new to AMP, however, I am not new to hosting or to Space Engineers. I am actually having several problems that only occur when using AMP to host a server.
  • MODS I currently run a GTXGaming server with 19 mods installed. The problem that seems to be on AMP is that it's adding mods to the config file. Nothing actually loads when the server starts and it says 0 mods. If I try to add them to the sandbox file it then just crashes the game. The mods are not incompatible with the game itself as I'm running them online server in the same config I was trying to do it on amp. Is there a workaround for this at all?
  • Store settings I may have gotten the title wrong, but it seems any changes to these settings do not make any in game impact. These settings are usually saved in the config file and even though the settings show accurately on the site, they do nothing in game (setting inv multiplier to 5 for example).
  • No Password option I had this problem with the GTXGaming servers as well and manually added a password hash and salt to the config files. I can't do that on this because it is instantly reverted back to a previous state. Please add support for passwords that is part of the origional dedicated server client.
Thank you for your time.
  • Session store changes do not seem to impact game (edited while not running)
Missing items from standard config • Enable Wolfs (enabled on AMP by default) • Enable Spiders (disabled on AMP by default) • No password feature • Settings made in session store do not impact the game.
I've just given up on the fact that adding mods though amp is broken since any way I know to do it breaks it only on AMP, but I have the steam client that can run them and gtx gaming that can run them w/o issues. No options for wolves/spiders can be a downer cause wolves are on by default and spiders are off which by default are both usually off.
I'll be patient and just wait for an update.
Mike posted this 18 May 2019
Just a note that I am aware, OP mentioned this on Discord. :)
martin8883 posted this 3 weeks ago
Hi, are there any news on this? Password is still missing from configuration options. And it would always be great for almost all games if there could be "Cubecoders is not aware of this attribute and I can set/overwrite on my own". Also all the descriptions and MOTDs don´t know linebreaks (like this board?). This way I am not aware of any possibilty to move my SE server to AMP. Could you provide any help? Regards Martin
Mike posted this 3 weeks ago
If SE didn't use XML then it would be possible, but unfortunately AMP has to completely de/re serialize the config file into a strongly typed structure - so the module has to be updated each time a setting is added/removed/modified.
Due to the small number of users SE has and the high development cost of maintaining it, the plan is actually to open source the module so the community can contribute changes to it.
For missing SE settings the best thing to do is to grab examples from the config file of the missing lines and create a post at https://github.com/CubeCoders/AMP/issues detailing exactly which lines are missing, where they go in the config file (and which config file they belong to).
Close
