Stuck in loading screen "Connecting to remote AMP instance..."
  • 85 Views
  • Last Post 2 weeks ago
  • Topic Is Solved
Salad posted this 2 weeks ago
OS: Windows 10 Home x86_64
AMP Version: 2.0.9.0
Problem: as the title says, i am stuck at that endless loading screen. its my first time using this programm. Its a minecraft instance that didnt get any managing or installment because i cant get into the managing site.
im not sure if i should post the logs and if idk which ones, but im happy to provide whatever the nice person helping me needs to resolve my issue.
Mike posted this 2 weeks ago
Right click that instance and select "View Logs", check if something is preventing it from starting.
Also the output of ampinstmgr status in a command prompt would be helpful.
[Info] AMP Instance Manager v2.0.9 built 04/01/2021 22:05 [Info] Release spec: Release - built by CUBECODERS/buildbot on CCL-DEV Instance Name │ Friendly Name │ Module │ IP │ Port │ Up ───────────────────┼──────────────────┼────────────┼─────────────────┼───────┼─── WebPanel │ Web Panel │ ADS │ 192.168.178.102 │ 6969 │ V FTBRevelations │ FTBRevelations │ Minecraft │ 192.168.178.102 │ 8081 │
and the logs say that the login server is unavailabe
You've changed ADSs IP binding, which requires that other settings are modified to accommodate this. ADS should be bound to 0.0.0.0.
so if i just delete all instances, make new onse and dont change the ip it works?
Delete the Minecraft and ADS instances, then open the GUI app back up so it runs through its first-time setup and don't change any network settings.
Close
