Field | Value |
Operating System | Windows - Windows Server 2022 on x86_64 |
Product | AMP ‘Callisto’ v2.5.0.0 (Mainline) |
Virtualization | Xen |
Application | Enshrouded |
Module | GenericModule |
Running in Container | No |
Current State | Stopped |
Any attempts to connect to SFTP on this instance fail. ampinstmgr ports
and ampinstmgr dumpfirewall
both don’t show the SFTP ports, so I assume they are being blocked by the firewall maybe? I’m not totally sure. However the web UI shows that the SFTP port 2224 is open (the indicator is green)
- Install Windows Server 2022 Core (no desktop environment)
- Add AppCompatibility, DirectX and VCRedist to the server
- Set up AMP server in Target mode. I have one controller and one other target but that’s not relevant
- Create Enshrouded game instance with default settings. Add it as a game server in Steam and test it (query ports and game ports work fine)
Update
I was able to get it working by following the instructions here to deploy OpenSSH on Windows Server.
This is probably something that installing AMP should take care of, but I guess since I’m using Windows Server Core, there are more features that aren’t available by default. I also had to manually installed DirectX, VCRedist, and ServerCore.AppCompatibility as per the this server install powershell script for Enshrouded.
I thought Windows Server Core would be more popular as an AMP target due to its reduced overhead by not having a desktop environment, but lack of support from AMP for this OS is a little troubling … especially for Windows-only game servers like Enshrouded, where Linux is not an option (not without using an extra layer like Wine).
