Scheduler Global Variables
AMP 2.5 has a number of global variables available to scheduled tasks in addition to the ones exposed by the trigger. They use the exact same {@Key}
syntax, but substitute different values. For example, {@CPUUsage}
will substitute for the current instances CPU usage.
Key | Description |
InstanceName | Name of the current instance |
InstanceId | ID of the current instance |
Uptime | Uptime of the current instance |
State | State ID of the current instance |
StartTime | Time the application was started within the instance (if running) |
ApplicationName | Name of the application as exposed by its configuration |
RAMUsage | RAM usage in megabytes |
CPUUsage | CPU usage as a percentage (without %) |
MaxUsers | User limit of the application (if applicable) |
UserCount | Number of connected users (if applicable/available) |
