OS Name/Version: Debian 11
Product Name/Version: (Always use the full version number - not ‘Latest’) AMP ‘Callisto’ v2.5.0.4 (Mainline)
Problem Description: Arma 3 Server not starting due to bash error.
provides syntax highlighting.
- Step 1 Created Arma 3 Instance
- Step 2 Update
- Step 3 When running server is wont run and gives me a bash error
Tried re-installing the instance with no luck. Logs below:
quit
[09:41:13] [steamcmdplugin:FrederickDeBargos Info] : SteamCMD Update successful
[09:41:13] [Generic:FrederickDeBargos Info] : Skipping download - target already exists (/AMP/arma3/233780/AMP_server.cfg)
[09:41:13] [Generic:FrederickDeBargos Info] : Skipping download - target already exists (/AMP/arma3/233780/basic.cfg)
find: ‘./arma3/233780/steamapps/workshop/content/107410/’: No such file or directory
[09:41:14] [Generic:FrederickDeBargos Info] : Merging config file ./arma3/233780/server.cfg (Template) using Unicode (UTF-8) encoding.
[09:41:14] [Generic:FrederickDeBargos Info] : Writing config file ./arma3/233780/battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[09:41:26] [API:FrederickDeBargos Activity] : Starting the application.
[09:41:26] [Generic:FrederickDeBargos Info] : Merging config file ./arma3/233780/server.cfg (Template) using Unicode (UTF-8) encoding.
[09:41:26] [Generic:FrederickDeBargos Info] : Writing config file ./arma3/233780/battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
find: ‘2841962803,/keys’: No such file or directory
find: ‘2841962803,/key’: No such file or directory
[09:41:38] [API:FrederickDeBargos Activity] : Starting the application.
[09:41:38] [Generic:FrederickDeBargos Info] : Merging config file ./arma3/233780/server.cfg (Template) using Unicode (UTF-8) encoding.
[09:41:38] [Generic:FrederickDeBargos Info] : Writing config file ./arma3/233780/battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[09:48:18] [Core Activity] : Authentication attempt for user FrederickDeBargos from 127.0.0.1
[09:48:18] [Core Activity] : Authentication success
[09:48:29] [API:FrederickDeBargos Activity] : Starting the application.
[09:48:29] [Generic:FrederickDeBargos Info] : Merging config file ./arma3/233780/server.cfg (Template) using Unicode (UTF-8) encoding.
[09:48:29] [Generic:FrederickDeBargos Info] : Writing config file ./arma3/233780/battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
