Startup Issue with Application Deployment - Fail to create New Minecraft instance over docker
Operating System Linux - Ubuntu 22.04.4 on x86_64
Virtualization VMware
Y can’t create a new instance of “Minecraft Java Edition” over docker. But I have a lot of instances runing of this, and I tried to deploy another game (Rus for example) and works
  • Click to create new instance in the menu “Instances”
  • Select “Minecraft Java Edition” and then select the correct datastore named “Big”. After creation: “Start always”
  • Afer wait to finish the job to configure instante, The AMP console shows a popup with this error: This task could not be completed: Create instance - Minecraft - State: 3. Startup failure: Docker returned error code 125
Can you share some logs? Maybe something in instance log or ADS log if the instance doesn’t get created
